Hi, I plan to use a PC to control some motors. The total amp under full load is about 60-80Amp, 12V. I have two devices (usb to rs485 interface adapter and a controller board with usb connection to the PC and several rs485 connectors to connect to the motors). Do I need to worry about the motors damaging the USB port of the PC? If so, what USB Isolator do you recommend? Thanks
