I am using a module that is identical to the typical application circuit design on page 3. The function block confused me a bit, I am not sure what are the discrete components inside the IC, again didn't expect to have to get to this point
There are no discrete components inside an IC. “IC” means “integrated circuit”, precisely because it is
not composed of discrete components. But in terms of functional blocks, you see a bunch of opamps/comparators and a MOSFET forming the core of it.
yes its too hot, these are listed at 4amps, obviously with forced cooling after some testing. I can't do active cooling.
The chip is rated for a 4A switching current. First off, the switching current ≠ the maximum output current. The maximum output current is also limited by the choice of external components. Those little modules are often… let’s just say “optimistically marketed” and aren’t capable of their rated specs.
The typical application schematic says right on it: output 18.5V/2.5A. Unfortunately the datasheet provides no engineering guidance whatsoever on how to design a whole circuit, so we can’t really calculate what the true output power of your module might be. (It might be possible to use the datasheet for the original part from TI that the XL6009 is a copy of. That happens to be the LM2577. The XL6009 is basically an improved version of the LM2577 with a 4A MOSFET instead of a 3A BJT in the original. Here’s the LM2577 datasheet, which is 4 times as long because it actually has some basic design guidance:
https://www.ti.com/lit/ds/symlink/lm2577.pdf )
I wouldn’t even bother trying to parallel them. They aren’t designed for that and the behavior might be unpredictable, and almost certainly won’t accomplish what you want.
Either buy a converter with the output power you need (plus headroom!), or if your load can be divided, split it up and give part to each module. (E.g. if your load is 100 lamps, divide them into two groups of 50, and put each group onto its own module.)
The resistors are suppose to keep the balance in check
You might get lucky and it works. Or you may get unlucky and blow up everything. Hard to predict since they’re not designed for it.
Those chargers are generic battery chargers nothing special, and is done everyday by millions of people. Think solar, generator, converter, and alternator. etc..
That doesn’t tell us any of the information we’d need to know. There’s no such thing, from an engineering standpoint, as a “generic” “nothing special” charger.
