I'm building a low powered PC with an external graphics card and noticed while testing everything for the first time that the graphics card would be constantly powered on, regardless of the state of the PC motherboard. As the motherboard and graphics card both run off separate 12V inputs, I'd thought I'd put a power relay on the input of the graphics card and connect the coil to a low-current 5V signal from the motherboard which would only be active when the PC was powered on.
Since the 5V signal will only ever be present when I want the power passing through the relay to the graphics card, is there any reason to add any further circuitry to the relay for practical or safety purposes?
