Yes, R1 is required for stability reasons. You can try reducing it, to get a better squarewave. I've just has a quick play with LTSpice and found that faster op-amps can tolerate having a lower R1.
Attached is the LTSpice file. If you've not got LTSpice, it's a free download from the Linear Technology website, which can be found using a search engine.
