One thing i still don't understand is the 50 ohm. What do they mean by 50 ohm on the coax cable. The resistance of the cables is not 50 ohms. I read on the net that it is for better transfer of electronic signals.
this is impedance, it depends on relation of distributed inductance to distributed capacitance of the cable.
In simple words, it means that cable will have 50 Ohm for just very short period of time, this short period of time is the time of electromagnetic wave propagation forth and back in the cable. As you know, it is moving with a speed of light, this is very-very fast. So, you can measure such 50 Ohm for very-very short period of time. When the wave come back to the input of cable it will change it's input resistance. The new resistance will depends on frequency, cable length and load resistance on the second end of the cable.
So, you cannot measure impedance with multimeter, because it's too slow for such measurements. There are exists special equipment for such measurements. For example, vector analyzers. You can also measure it with LC meter.
Actually the things is a little more complicated, because wave propagation speed also depends on distributed inductance and distributed capacitance of the cable. What you're needs to know is relation between impedance and distributed inductance and distributed capacitance in transmission line:
Z = sqrt( L / C )
and wave propagation speed:
v = 1 / sqrt( L * C )
Where:
L - distributed inductance [H/m]
C - distributed capacitance [F/m]
You can use LC meter in order to measure L and C values. Use long piece of cable for better precision (for example 5-10 meters), because short piece of cable has too small capacitance and inductance and it will be hard to measure.
Then measure L of the cable shortened on the second end. And measure C of the cable open on the second end. Then divide these values with cable length. For impedance you can just ignore cable length and use total L and C of the cable. For wave propagation speed you're need to divide it with cable length.
Usual RG58 coax cable has about the following L and C:
C = 100 [pF/m]
L = 250 [nH/m].
It may vary for different manufacturer. Let's calculate it's impedance:
Z = sqrt( 0.000000250 / 0.000000000100 ) = sqrt( 2500 ) = 50 [Ohm]
v = 1 / sqrt( 0.000000250 * 0.000000000100 ) = 1 / sqrt( 0.000000000000000025 ) = 1 / 0.000000005 = 200'000'000 [m/s]
As you know, speed of light in the vacuum is 299'792'458 [m/s], so the wave propagation speed in RG58 cable will be slower than speed of light in the vacuum. The relation of this speed to the speed of light in the vacuum is known as velocity factor of the cable:
RG58 velocity factor = v / c = 200'000'000 / 299'792'458 = 0.667
In the same way you can calculate impedance and wave propagation speed in the vaccum. Distributed inductance and capacitance of the vacuum are known as physics constants -
magnetic permeability and
electric permittivity of the vaccuum:
L = μ0 = 4 * pi * 1e-7 [H/m]
C = ε0 = 8.8541878128e-12 [F/m]
Z = sqrt( (4 * pi * 1e-7) / 8.8541878128e-12 ) = 376.73 [Ohm]
v = 1 / sqrt( (4 * pi * 1e-7) * 8.8541878128e-12 ) = 299'792'458 [m/s]
This 376 [Ohm] is known as impedance of free space.
And this 299'792'458 [m/s] is known as speed of light in the vacuum.
Now you're ready to understand - simple wires with alligators will have random and variable inductance and capacitance through it's length. This is why it's impedance will not be constant through it's length. And this is why it so much affects measurements for high frequencies.
