Originally, I wanted to design a single high-gain amplifier (Av = 100) for a 40kHz sinusoidal signal. So I started simulating the design in LTSpice using LT's built-in components to save some time. However, the gain at 40kHz was about 70% lower than I expected. So I stripped down the circuit until I was left with a voltage follower with unity gain (see attached image).
The datasheet says that the gain bandwidth product (GBWP) for the LTC6240 is 18Mhz. However, the bode plot of LTSpice says that it is only about 130kHz. How can that be? Or did I misunderstand the concept of GBWP?
Thanks in advance.
