Well a few days ago I wound up a wound up led light too fast and all the lights went out at the same time. I took it apart and it had a wind up motor, 4 rectification diodes, one current limiting resistor, and maybe a supercap or nicad across the bridge output. The diodes tested ok with the meter, the resistor I tried shorting, and the nicad was outputting. So I looked for the resistance of the diode and they were near zero, and I argued they were shorting the whole thing out. I cut them off and tried a led in its place and it lit up, but did not with them attached. At least in this case, they definitely failed closed.
