Author Topic: Do we need Saw waves ?  (Read 6646 times)
Offline Kiriakos-GRTopic starter
  • Country: gr
  • User is banned.
    • Honda AX-1 rebuild
« on: May 18, 2011, 05:45:00 pm »
Yes , do we need Saw waves ?   :-)
I would like to know , in what cases , you do use Saw waves for ?
Like testing a gear ?
Or use it, so to repair something ?
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: Do we need Saw waves ?
« Reply #1 on: May 18, 2011, 05:50:56 pm »
err.... no saw waves = no TV's, CRT monitors or CRT scopes. Really are you truly asking such a silly question ?
Offline johnmx
  • Country: pt
« Reply #2 on: May 18, 2011, 06:17:51 pm »
It's widely used by PWM controllers, music synthesizers and many more.
Best regards,
johnmx
Offline Simon
  • Global Moderator
« Reply #3 on: May 18, 2011, 06:27:48 pm »
yep that too, although can be often interchanged with triangle waves but then a saw tooth is a triangle I suppose with 100% duty on the rising or falling edge
Offline Neilm
« Reply #4 on: May 18, 2011, 07:26:20 pm »
Look at the current waveform in a flyback PSU transformer - if you see a nice sawtooth waveform you can tell you have the frequency and duty cycles reasonably correct.
Neil
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
  • Country: gr
  • User is banned.
« Reply #5 on: May 18, 2011, 09:15:46 pm »
It's widely used by PWM controllers...............
Well from what I have read so far , the PWM uses square waves with controllable duty cycle.
  • Country: gr
  • User is banned.
« Reply #6 on: May 18, 2011, 09:17:06 pm »
This is the  Beginners club ... I love silly questions  :P
Offline johnmx
  • Country: pt
« Reply #7 on: May 18, 2011, 09:44:42 pm »
I have 4 different PWM controllers in stock: DRV591, DRV593, MCP1630V and TL594. All of them use a sawtooth waveform (AKA ramp) to control the duty-cycle.
Let me google a picture….got one (see attached). If those two signals (in black) are the input of a comparator then the PWM signal (in blue) is generated. If one input signal is higher than the other, then the output will be low, else will be high. The period of the PWM signal is the same as the sawtooth waveform.
Best regards,
johnmx
Offline RayJones
    • Personal Website
« Reply #8 on: May 18, 2011, 11:18:26 pm »
Sawtooth waves are very much used all over the place.
Useful for time bases, ala horizontal analogue CRO beam deflection, CRT monitors (sawtooth current actually), ranging systems, servo system error determination (ala PWM feedback).
Heck even your prized Fluke DMM probably uses saw waves for the dual slope conversion system.
Let's not forget they also are good for cutting wood  ;D
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #9 on: May 19, 2011, 12:47:18 am »
from what i google not so long ago. sawtooth waves consist of all integer harmonics, ie 1,2,3,4 where square, albeit infinite, do not consist all integers, if i'm not mistaken, only odd integers, ie 1,3,5. so sawtooth is better at analyzing other signal's noise/thd, and mostly used in audio... well, thats what i read, i never got involved in audio.
Offline allanw
    • Electronoblog
« Reply #10 on: May 19, 2011, 06:02:40 am »
PWM uses a sawtooth wave. Digitally, there's a counter that decides when to turn the PWM signal on or off. You can look at this as a signal as a sawtooth wave and a comparator that toggles the PWM signal.
Function generators can be implemented with something that generates a sawtooth wave. A square wave is generated with a comparator (same as PWM). A sine wave is generated by filtering out the higher frequencies.
It can also be useful for testing clipping distortion in amplifiers. You can visually see if the sharp corner of a triangle wave is missing.
  • Country: gr
  • User is banned.
« Reply #11 on: May 19, 2011, 08:20:03 am »
This is a great TIP ..
Thanks allanw.
Nice TIP  too ... LOL  ;D
« Last Edit: May 19, 2011, 08:23:15 am by Kiriakos-GR »
Offline RayJones
    • Personal Website
« Reply #12 on: May 19, 2011, 08:29:47 am »
Boom tish
