Are you trying to test the transistor while in circuit or out of circuit? If in circuit, you may be seeing the effects of other components, like capacitors. If out of circuit, you need to use the diode test function, base to emitter, emitter to base; base to collector, collector to base. If it is an FET, then there is a different procedure to use with a multi-meter.
