I have enough parts laying around know that I can build a pretty nice linear bench PSU without buying anything most likely, since I dont have one it sounds like a fun project. I am shooting to build a dual channel that can be arranged in bipolar mode. I found a nice multi tap transformer in my junk from an old onkyo receiver. I tested it the secondary output with a continuity test and it appears to have two center-tatped outputs. It has a set of brown, blue and yellow wires with a white and orange. It appears that the white wire is a center tap for the blue and brown sets and the orange is center tap for yellow.
Here is an image
https://www.dropbox.com/s/gj1dhf4sbutge9y/psuStuff.jpg?dl=0 Testing the voltage I get
Brown to Brown - 56vAC
Blue to Blue - 31.5vAC
Brown to White - 28vAC
Blue to White - 15.7vAC
Yellow to Yellow - 35.75
Yellow to Orange -17.88
So what I need to know is if I use a connection like White to Orange which gives 7 volts, or since these are on what appears to be on different output coils is this not a good idea? Secondly how do I go about testing the amount of current the transformer can safety deliver? The model number is HAWK h86-002A, I cant find any data on the thing, im wondering if 002A means 2 amps. Im not interested in my PSU being high current, but pushing at least 2A on each channel simultaneously would be great,
Somewhat off topic but may as well bring it up here, when you look at most bench psu's online they all use a voltage ref with an opamp and pass transistors, what exactly is the benefit of using a self made regulator vs a current limiting circuit followed by a plain old adjustable regulator, I dont see very many adjustable supplie schematics using a 3 pin regulator and I am curious why.
