Electronics => Beginners => Topic started by: little_carlos on September 14, 2015, 12:40:45 pm
Hi, i was wondering about that yesterday and i hope you can answer this
since the relay inputs are activated with an electromagnetic field, does that magnetic field causes any noise or interference to any signal that goes through ?
There can be some spikes if you are using stable DC to drive the solenoid but like a transformer with a thousand-turn primary and a one-turn secondary the noise is minimal.
However the real concern here is contact bounce which can be significant if you bought one with unsatisfying quality.
If you are asking if there is any coupling of 'noise' from coil/magnetic field to the output contacts, then no, there is no realistic concern there.
Yes, repeat no.
In other words it depends on the type of relay, the operational environment, and the signal.
In this very sensitive application, some precautions in the relay were taken to prevent noise :
http://electronicdesign.com/test-amp-measurement/whats-all-femtoampere-stuff-anyhow (http://electronicdesign.com/test-amp-measurement/whats-all-femtoampere-stuff-anyhow)
- shielding between coil and contacts
- reduced voltage range on the coil.
