Hi Ian, thanks for the reply. I attach the schematic below, I have taken signals at the pink starred points to HEF4001's configured as set / rest flip flops, in the case of the first measuring point, which goes Low on loss of drive signal, I have put it through an inverter. This works fine and a separate LED is lit, and stays lit if drive signal is lost, PA current rises too high, or reflected antenna power rises too high. This improves on the shown circuit which just lit the one LED no matter which of the 3 protection circuits was triggered, so you didn't immediately know why it had tripped.The simple reflected volatge measurement shown is OK'ish at full power where a mismatch can return over 5V to the flip flop and it's then triggered, but a t low power, using a reduced PA FET voltage, not enough reflected voltage is seen by the HEF2001 SR flip flops (not shown) to trigger it, even with no antenna connected. Hence the need to compare the percent difference between forward and reflected voltage from the bridge.
Complicated to explain concisely, I hope you can follow my rambling?
Some hysteresis would be good to stop shuffling. Can you see any issues with your kind suggestion based on the above and the attached schematic? Thanks again Ian!
