So I've begun to learn OP-AMPS and don't quite understand why the book I'm learning from had done something in one of the example problems. I attached three pics from the book related to this problem.
I know it says that if the load resistance is greater than or equal to 10K that I need to add and subtract 1V from the DC sources, AKA limits. I know that if the load resistance is between 2K and 10k and I have to add and subtract 2V from the limits. It doesn't say anything about a load resistance below 2k though. It says refer to the graph, which I did. It says the limit for a 1.5K load is 25Vpp, assuming that the DC sources are 15 and -15V. Fine. But then it says that the source voltages for the circuit are well below the limit for 1.5k and that we can safely assume that the load will not restrict the output voltage swing. Thus....... im going to pull a 2v from my arse to be added and subtracted from the limits and not explain how that came to be.
What does it mean that the load will not restrict the swing because the source voltages are well below the limits?
So what im gathering is that IF the source voltages for the circuit were 15V and -15V, a 1.5k load will have a maximum output of only 25Vpp?
Why am I adding and subtracting the 1V or the 2v, depending, from the limits? I know that the output cant exceed the source limit, 15V and -15V, because it will clip or does it clip when it exceeds the limit after I added and subtracted the 1V or 2V?
Can someone please shed some light on this for me.
