Author Topic: Recreating a CRT style Radar display with a LED matrix  (Read 2037 times)
Offline rthorntnTopic starter
« on: August 01, 2018, 06:39:32 am »
Update: I think this might be a bit OT, sorry about that.
Another update: Maybe the best bet is just to use 0201 LEDs real close together in a grid, like reDOT.
I'm thinking of something like this https://www.youtube.com/channel/UCagly25EuaH5Wi1LhxUQNQg but:
I cant really get my head around whether this is even possible, if I want the radial sweep to be one LED wide (1 degree) at the outside, what do you have to do to the LEDs as you go towards the centre.
I really should have paid more attention in maths.
Thanks for looking.
Cheers
Richard
« Last Edit: August 01, 2018, 08:09:29 am by rthorntn »
Offline hendorog
Re: Recreating a CRT style Radar display with a LED matrix
« Reply #1 on: August 01, 2018, 08:20:44 am »
Reminded me of this:
https://forum.kicad.info/t/python-scripting-example-studio-clock/5387
Which might actually be hackable to do what you want.
The following users thanked this post: rthorntn
Z80
  • Guest
« Reply #2 on: August 01, 2018, 09:19:46 am »
Draw circles at the led spacing and distribute leds evenly around them.  There will be less on each ring until you reach the centre where there will be 1.  The line obviously won't be perfectly straight but will zig zag with leds being shared between steps, a diffuser over the panel will help smooth it out.  The challenge will be driving it, probably best to put the leds on the top and the drivers on the bottom and either implement the pattern generator locally or if you want other stuff on the screen then use a high speed serial link to the controller.
Online PA0PBZ
« Reply #3 on: August 01, 2018, 10:20:50 am »
Can't help to think that a cheap LCD display would be so much easier...
« Reply #4 on: August 01, 2018, 10:48:11 am »
I don't know of any big round LCDs... but a bit of waste cardboard, compass, protractor and a scalpel could fix that.
Online PA0PBZ
« Reply #5 on: August 01, 2018, 10:58:16 am »
I was thinking about a bezel with a round hole in it, but if you need the circumference to be round it is a bit more difficult. Alibaba is full of 3.4" 800*800 displays but anything bigger will be $$ I guess.
« Reply #6 on: August 01, 2018, 11:06:36 am »
Could you please expand on that, does aliexpress have 3.4" round LCDs?
Online PA0PBZ
« Last Edit: August 01, 2018, 11:26:20 am by PA0PBZ »
Offline t1d
« Reply #8 on: August 01, 2018, 04:36:42 pm »
RPi (cheap), plus
Video Player Program, plus
Display, of your choice, plus
Video editor software (Free/OS. Maybe run it on a bigger computer, faster/ more powerful, to create the video)
Take a picture of, or clip, or import, the beginning desired display picture. Take a separate copy, of the image, and add any features, that you like... A new radar image, an Indiana Jones style moving flight line, etc. Crop the before and after pictures, in Paint (etc.), to create the round screen, that you want. Save the first and second picture, separately. Place the two pictures, on the video editor timeline. Use the video editor's sweep transition feature to morph between the two images. Spread the sweep out, over time. Radar sweeps are, often, a transition sweep type. Create the "movie." Run it, on the RPi.
Here's my tutorial:
Offline james_s
« Reply #9 on: August 01, 2018, 04:38:02 pm »
It's certainly possible. One of my FPGA projects is a 70s arcade game called Atari Subs. It displays a fairly convincing radar sweep display in the corner of the screen which is a small corner of a standard resolution raster display. I doubt it is more than a few dozen pixels wide. When the sweep is moving you don't notice that it's a little bit jaggy.
« Reply #10 on: August 01, 2018, 10:12:51 pm »
I'm thinking the "round LCD" PA0PBZ shared, connected to an RPI and stuffed in a case could be cool.  Thanks everyone.
Offline james_s
« Reply #11 on: August 01, 2018, 11:47:50 pm »
It's definitely going to be hard to beat the resolution of one of those.
For lower resolution displays my suggestion would be to draw the grid of pixels out on paper and then draw each position of the sweep such that it looks as pleasing as possible. All you need is 1/8th of the radius and you can get the full rotation by swapping and mirroring the X and Y axis. No need to do any fancy math to calculate it.
« Reply #12 on: August 02, 2018, 05:03:33 am »
Anybody got any ideas on how to get these cool 3.4" round screens, I can only see them on alibaba and I think alibaba is more about selling to companies in quantity that handle the logistics?
Offline Beamin
  • If you think my Boobs are big you should see my ba
« Reply #13 on: August 02, 2018, 05:17:00 am »
Those panels on mikeselectricstuff with a diffuser. Cost about 50$ or less.
Max characters: 300; characters remaining: 191
Images in your signature must be no greater than 500x25 pixels
Offline james_s
« Reply #14 on: August 02, 2018, 05:52:53 am »
I don't know about 3.4", but round TFT displays are readily available from Chinese ebay sellers.
