Hi there everyone.
I'm hoping to make an auto-ranging voltmeter using the Renesas
ICL7135 4 1/2 Digit, BCD Output, A/D Converter.
Now, my experience with logic/digital is very limited, I almost exclusively work with analog, so, I was hoping that there would be an application note which would demonstrate an example of an auto-ranging circuit. Unfortunately, the app note for this chip,
AN017 does not contain this information, and neither does the datasheet.
However, I did find an app note for an older/obsolete part,
AN028, which does show an autoranging circuit (page 4), and it should be completely compatible - it's just using the "under-range" and "over-range" outputs, which the ICL7135 shares.
However, there appears to be a number of issues with this reference circuit.
There's an AND gate labelled 7403, but a 7403 is a NAND, another AND labelled 7406 which is an inverter, a NOR labelled 7462 which is I don't know what, and another NOR labelled 7482 which is an adder.
Basically, I can't make heads-or-tails of it.
I emailed Renesas asking about the discrepancies I'd found, and was at first brushed off and told that it was an obsolete part. Once I mentioned that I was applying the information to a current part because the information wasn't presented elsewhere (that I could find), I got a bit of information.
Was told the 7482 "NOR" should be 7428. The four numbered AND - one labelled 7403, the other three labelled 7406, should all be 7406 NAND.
The 7462 should be 7402.
Now, that all seems to make sense to me, but as I said, I'm not at all confident with my logic skills. Do these corrections make sense to the people here? Should this get me a functional autoranging circuit?
And one last question. Both the application notes and the datasheet all suggest using a trimpot for trimming the 1V ref voltage, using a zener or 1.2V reference IC. I would think that an accurate 1V reference IC like
ADR130 with no trim would be a much better idea, or is there some potential pitfall I'm overlooking?
