Author Topic: Don't understand how to read datasheet for OLED display, also current resisting?  (Read 1017 times)
Offline Mp3Topic starter
Hi all, two questions.
I just bought one of these displays to replace an old EL backlit LCD from a device with a dead inverter. https://www.mouser.com/datasheet/2/427/oled040n002alpp5n00000-1153452.pdf
1. I can't tell from the datasheet what i need to do to switch it between 4 bit and 8 bit mode. I don't know which I actually need. I know these displays are a drop in solution but i don't know whether they are set to 4 bit or 8 bit by default. https://www.buydisplay.com/default/4002-40x2-character-lcd-display-module-hd44780-white-on-black
2. Will i need a current limiting resistor on the OLED? If so where would i put it?
High school graduate
Offline mariush
The OLED display uses OLED-100 controllers which seem to use the same command set as those HD44780 modules
You can find a datasheet of some sort here: https://docs-emea.rs-online.com/webdocs/1401/0900766b814011cc.pdf
The standard hd44780 or clones can work either in 4 bit mode or 8 bit mode - YOU select the mode during initialization.
In 4 bit mode, you only need to use RS, RW, EN and 4 of the 8 data pins... actually only RS is needed out of the RS,RW and EN - you can hardwire EN to have the lcd always on, and you only need RW connected to a microcontroller if you need to read data from the lcd display back to the microcontroller. For just controller to lcd communication, the RW can be left unused.
Here's a display which uses a clone of that hd44780 chip, with the same instructions : http://www.newhavendisplay.com/specs/NHD-0208AZ-FL-GBW.pdf
You can see the pinout and the way you'd connect in 4bit mode or 8bit mode, and how you use a potentiometer to adjust contrast.
Also, you have in that datasheet the minimum of instructions you need and code that shows you how to initialize the display in either 4bit mode, or 8bit mode.
The datasheet also links to the full documentation for that controller, which is here: http://www.newhavendisplay.com/app_notes/ST7066U.pdf
OLED displays shouldn't need a backlight, so I don't see why you'd use a current limiting resistor.
The following users thanked this post: Mp3
