The problem I see is that if I use the BNC-BNC the single block looks good, if I use the rigol probe x1, they look good, worry if I use them x10, the peaks appear, they only disappear if the amplitude is 6 volt or higher, can someone tell me what can it be?
Rigol ds1054z and FY6900 20Mhz
- the first image, with BNC-BNC cable (provided by feeltech), without attenuation of 20Mhz
- the second image, with BNC-BNC cable (provided by feeltech), with 20Mhz attenuation
- the third image, with probe of the rigol ds1054z, without attenuation attenuation of 20Mhz.
- the fourth image, with probe of rigol ds1054z, with attenuation attenuation of 20Mhz.
-the fifth image, with probe of the rigol ds1054z, without attenuation attenuation of 20Mhz. but the selected amplitude is 6V. The peaks are not exaggerated.
1-
Subido en
subir imagenes2-
Subido en
subir imagenes3-
Subido en
subir imagenes4-
Subido en
subir imagenes.
5 -
Subido en
subir imagenes
