Author Topic: Help! My coffee machine is broke...  (Read 1992 times)
Offline m4ttybTopic starter
  • Country: wales
« on: May 27, 2020, 11:10:45 am »
Hi, my coffee machine won't switch on...😲😲😲
I've dismantled it and have possibly found the culprit.
But I need help identifying the value of the capacitor/resistor???
Please help, I need my coffee...
Photo attached...
« Last Edit: May 27, 2020, 11:20:43 am by m4ttyb »
Offline Shock
Re: Help! My coffee machine is broke...
« Reply #1 on: May 27, 2020, 11:36:15 am »
Yeah the give away is that little bubble on the surface and then the crack on the side. Please also include the brand and model number of what you are working on so others can benefit from it.
  • Country: wales
« Reply #2 on: May 27, 2020, 11:47:42 am »
Thanks for the response, here's a few more pics...
  • Country: wales
« Reply #3 on: May 27, 2020, 11:53:44 am »
No.
Offline Jwillis
« Reply #4 on: May 27, 2020, 10:03:10 pm »
1mH inductor
LNK364GN  Energy Efficient, Low Power Off-Line Switcher IC https://www.mouser.ca/datasheet/2/328/lnk362-364-1511784.pdf
Offline Shock
« Reply #5 on: May 27, 2020, 10:26:41 pm »
Orange Black Red Gold 3mH?
Going to also want to check the diodes around that area as well.
« Last Edit: May 27, 2020, 10:31:52 pm by Shock »
Offline SilverSolder
« Reply #6 on: May 28, 2020, 12:21:00 am »
Broken coffee machine is pretty much the worst case scenario in any work environment!  :D
Offline SparkyFX
« Reply #7 on: May 28, 2020, 12:44:16 am »
These LNK364 fail so frequently in washing machines, there are sellers on ebay offering bundled kits of LNK364 with inductor and resistor. Guess they don't survive surges very often.
Support your local planet.
Offline wizard69
« Reply #8 on: May 28, 2020, 01:58:08 am »
Critical survival equipment needs a backup.    Sort of like the beer (or coke zero) fridge in the garage.
As for what that deice is I have no idea.
Photo attached...
Offline Jwillis
« Reply #9 on: May 28, 2020, 08:18:46 am »
Looked like brown , black , red , gold to me .But you could be right .
Offline dietert1
  • Country: br
    • CADT Homepage
« Reply #10 on: April 22, 2022, 05:08:31 pm »
Got some LNK364 from a local store for a repair and they appear to have an alternative pinout, with BP on pin 1 and Gnd on pin 3.
What's that? Couldn't find anything on the web.
Regards, Dieter
Offline mjwallin47
« Reply #11 on: April 23, 2022, 06:32:34 am »
Could be a 1000 ohm resistor?
Offline DavidAlfa
« Reply #12 on: April 23, 2022, 09:53:01 am »
After 2 years, I don't think he's working on it anymore  :palm:
The following users thanked this post: HobGoblyn
Offline dietert1
  • Country: br
    • CADT Homepage
« Reply #13 on: April 23, 2022, 10:37:48 am »
Maybe the LNK364 is a good ebay seller because the alternative pinout variant i found dies immediately when used as a replacement. LNK364 can't stand a short on BP.
Regards, Dieter
Offline jonpaul
« Reply #14 on: April 23, 2022, 12:33:13 pm »
We gave up on automatic espresso and café machines, complicated, need maintance and bad coffee.
Even Swiss made Jura and Capresso are unreliable.
Suggest you check the Bialetti Italian  Moka pot stove top
https://www.bialetti.com/it_en/moka-express-experience
Great café and moka, easy to clean and no electronics!!!!
Enjoy
Jon
Jean-Paul  the Internet Dinosaur
The following users thanked this post: nightfire
Offline Kean
    • Kean Electronics
« Reply #15 on: April 23, 2022, 10:40:08 pm »
In case it helps anyone in future, here are my notes from repairing my DeLonghi Lattissima Nespresso machine in May last year.
Not powering on
No LEDs
Draw 1VA (<<1W)
PCB labels: "Nespresso Lattissima Switching" "05/07/2010" "Procond Elettronica"
When removing PCB, labelled wires as F1, F2, F3, F7 etc
PIC18LF2520-I/SO - only getting 1.8V for power pins
Uses LNK364GN (Power Integrations) chip
R55 = 47R 3W 5% fusible resistor - open circuit
L1 = 1000uH (1mH brown black red gold) measured 1.6uH 1.6R and signs of damage
C1/C3 = 4.7uF 400V Nippon Chemicon KMG Series 105C (EKMG401ELL4R7MJ16S) measure OK & 4R ESR
Replaced
- L1 with Bourns RLB0913-102K (1mH 350mA) slightly too big to fit between caps
- R55 with 2 x 100R 2W Ohmite resistors (parallel)
Still didn't power on - and the 100R resistors are now open circuit
Internal short in LNK364
Ordered from RS
- LNK364GN
- Vishay 47R 3W AC03 Fusible Safety Resistor
- Epcos B82144A 1mH 200mA 3.8RDC Axial Inductor (bigger than old one)
Fixed!
