Author Topic: converting Volt into dB  (Read 6531 times)
Offline schmitt trigger
  • Country: mx
Re: converting Volt into dB
« Reply #25 on: August 09, 2019, 05:01:41 pm »
Indeed, one can use decibels for many purposes. Many prepostperous.
In my previous job, since it was a public company, the CEO's compensation was available.
As a prank, we started calculating how many decibel dollars (dB$) our pay compared to the CEO's compensation.
Because it was purchasing POWER, it was calculated as: 10log(my$/$CEO$)
Of course, the results were always negative  :-DD
The following users thanked this post: kakabouras
Offline soldar
« Reply #26 on: August 09, 2019, 10:27:56 pm »
I reiterate that decibels are a measure of power ratio.  Any other use is perversion.
Can we have a cite for that? Because Wikipedia disagrees and cites ISO 80000-3:2006.
https://en.wikipedia.org/wiki/Decibel
In the International System of Quantities, the decibel is defined as a unit of measurement for quantities of type level or level difference, which are defined as the logarithm of the ratio of power- or field-type quantities.
Offline Audioguru again
« Reply #27 on: August 10, 2019, 02:01:47 am »
The voltage gain of opamps is measured in decibels.
The voltage gain of audio power amplifiers is measured in decibels.
The voltage cutoff frequency of a filter is measured at -3dB.
The voltage reduction of a logarithmic volume control is measured in decibels.
Offline soldar
« Reply #28 on: August 10, 2019, 11:34:51 am »
Another cite:
https://en.wikipedia.org/wiki/Gain_(electronics)
The term gain alone is ambiguous, and can refer to the ratio of output to input voltage (voltage gain), current (current gain) or electric power (power gain).[4] In the field of audio and general purpose amplifiers, especially operational amplifiers, the term usually refers to voltage gain,[2] but in radio frequency amplifiers it usually refers to power gain.
Another: http://www.sengpielaudio.com/calculatorVoltagePower.htm
« Last Edit: August 10, 2019, 11:56:33 am by soldar »
Offline mikerj
« Reply #29 on: August 10, 2019, 06:37:22 pm »
You can reiterate it as many times as you want, but unless you back it up with some actual evidence then I'm just going to ignore it.
Offline magic
« Reply #30 on: August 10, 2019, 07:21:17 pm »
Worth noting that when it refers to voltage gain, it's still reported as the equivalent power gain under assumption of equal load impedance. That is, a 10x voltage gain is reported as 20dB because it corresponds to 100x power gain, not as 10dB because it's a 10x gain.
Just Wikipedia being a misleading pile fo turd as usual :--
Offline soldar
« Reply #31 on: August 10, 2019, 07:56:09 pm »
You pervert, you!  :)
The following users thanked this post: mikerj
