Author Topic: Is this supernode equation setup right or wrong ?? Plus most of the eqns used  (Read 310 times)
Offline MathWizardTopic starter
I'm just reviewing superpostion of nodes and meshes, before trying some Modified Nodal Analysis, and Newtons method on systems of non-linear equations. But a few of them I'm getting wrong and I can't find the mistake on paper or in the spreadsheet where I'm doing the calculations.
So here's an example, that was even more right a moment ago, but V2 was wrong, but then I found a silly mistake, and now all node voltages are more wrong.
And it's SUPERNODE(1+3)
The other morning I put the instant coffe in the kettle, instead of the water, but that was due to thinking about ladies...
« Last Edit: June 29, 2026, 05:54:45 am by MathWizard »
Ok why do I have the 2* in i5=2*G5*V3, thats wrong, probably because the last time I tried the problem, I called Vb=2*Vx, V3
I'm glad this isn't some mid-term
Offline ledtester
SUPERNODE (1+2)
ENTERING = LEAVING
(i2 + ia) + (i4 +iv) = (i1 + iu) + (i5 + ia)
w.r.t. supernode 1+2, i2 is an internal current and so it shouldn't appear in the entering = leaving equation.
(Or, it both enters and leaves the supernode.)
Yeah I saw that right away, thats just a typo it's node1+3
Now after fixing the big mistake, which was just G9 should equal = G4+G5, now it works. So without my extra composite G's which aren't labelled the best, since I was just trying to save myself page space as I went
for node 2, eqn 1 would be
-(2*G3 + G4)*Va = -(G2 + 2*G3 + G4)*V1 + (G2 + 3*G3 + G4)*V2
and the supernode (1+3) would give eqn 2
iv - iu + (G4 + G5)*Va = (G1 + G2 + G4 + G5)*V1 - (G2 + G4)*V2
now finally it works, but I tried it 2-3 times and probably just had a silly mistake each time.
I need to be more careful, I was worried the method was wrong, and just working by fluke sometimes, so I thought maybe my assigned currents had to match the way I used them at node 2 or IDK...and in this case I did make them match
