The recommended type for drag soldering is the type BCM or CM. The BC or C will work as well. The type with a small hole in it should be better, because you have a small reservoir of solder, with that you can remove too much solder from bridged pins, because the solder flows back to the hole. Or at least should flow, I haven't tested it until now.
