thanks, I would like to use seeedstudio's fusion service as fab
i'm still waiting reply from them about the milling specs
anyone has experience with this fab ?
I've drawn the cutout
outline using a thin but not zero line (as I've seen in other providers spec for milling, for example oshpark.com that it is preferred, plus adding the cut out indication on the same layer)
I've also added the text "cut" inside the area that should be removed, again on the milling layer (the slots are very small and I cannot fit the "cut out" word, I hope this would not cause issue)
is it better to add the "cut" indication on another layer?
I've understood that usually the fab uses the outline on the milling layer (considering the center of the line regardless its width) to calculate the path of the milling machine that will in turn create the hole.
is my understanding correct?
does anyone have other advices for a noob like me ?
thank you!
