Author Topic: driver to 12v LED strip???  (Read 1101 times)
ddmeltzer8
  • Guest
« on: January 14, 2019, 05:41:34 pm »
Hello!
Im planning on installing some LEDs in my mothers kitchen.
I already have the LED strips (5630).It will be about 3-4 m long.
My question is what i should do for driver?How good r the cheap ones on ebay?
Thanks in advance.
Offline Zero999
  • 0999
Re: driver to 12v LED strip???
« Reply #1 on: January 14, 2019, 09:00:16 pm »
All that's needed is a 12V power supply. Buy a decent brand, from a reputable store.
Offline Zero999
  • 0999
« Reply #2 on: January 17, 2019, 11:49:37 am »
You didn't specify how many Amps the LED strip needs.
LED strip has built-in current limiting resistors, so requires a constant voltage supply. Choose a 12V power supply with an equal or higher current rating, than the LED strip requires.  There's no need to worry about fire, so long as you use a decent branded power supply, with over-current protection and suitable cable for the current rating.
