Author Topic: Driving a small speaker with an H-bridge?  (Read 1670 times)
Offline S. Petrukhin
  • Country: ru
Re: Driving a small speaker with an H-bridge?
« Reply #25 on: February 03, 2024, 04:00:52 pm »
and those optos are not only high resistance, they are also slow as molasses
Optos are not required, it is not related.
And sorry for my English.
Online langwadt
« Reply #26 on: February 03, 2024, 04:07:44 pm »
then why did you suggest it? https://www.eevblog.com/forum/beginners/driving-a-small-speaker-with-an-h-bridge/msg5312593/#msg5312593
  • Country: ru
« Reply #27 on: February 03, 2024, 04:20:02 pm »
Online ebastlerTopic starter
« Reply #28 on: February 03, 2024, 04:43:19 pm »
a step-up will only increase the problem of high resistance switches
Thanks for pointing out the speed issue; that's another reason to avoid optocouplers. I don't see why one would use them in a 3.7 V system. And I don't see the point in transformers either for driving a small low-impedance speaker.
I will try the small H bridge (DRV8212), which I would consider the most elegant solution. But will also order a small integrated class D amp with internal PWM generation (PAM8302) as a fallback; maybe the dual-PWM beat frequency I am concerned about is not an issue in practice. And I do have a few small class AB amplifier ICs around -- they definitely work, but get less power to the speaker than I would like.
Thanks again to all who have provided advice!
Offline LinuxHata
« Reply #29 on: February 04, 2024, 04:37:43 pm »
I guess, something like LTC1157 can be used for that task, but price....
Offline JustMeHere
« Reply #30 on: February 06, 2024, 12:22:49 am »
This amp is probably overkill for your application, (and you will need a boost converter somewhere) but maybe you can find one out there that fits our needs.  Takes PWM directly.
https://www.ti.com/product/TAS5103
