Author Topic: Driving an optocoupler from 28V AC?  (Read 7515 times)
Offline Dave WaveTopic starter
« on: August 29, 2012, 04:41:56 pm »
I want to drive an optocoupler from a 28V AC source that will output a signal to an Mega8 microcontroller so I can read if the source is off or on.
I am assuming the 28VAC will be noisy as it direct from a transformer and driver relays that are switching 120vac, hence the optocoupler.
My intital thoughts are use a full wave rectifier to convert to DC, then a small resistor to drop the current for the optocoupler. I assume this is going to be wasteful with the resistor radiating a couple watts or so.
Is there a more elegant solution to my issue?
Thanks for the help,
-Dave
Re: Driving an optocoupler from 28V AC?
« Reply #1 on: August 29, 2012, 05:59:25 pm »
Single IN4148 diode in reverse across the IR diode in the optocoupler, then a resistor to allow 2-3mA to flow in the optocoupler. 10-12K rated at 0.25W resistor will do. You can also get an opto with AC input, it has 2 diodes in the device connected in anti parallel. To filter you take the output and use a RC filter to get the signal and remove the 50/60Hz hum on it.
« Reply #2 on: August 29, 2012, 09:48:03 pm »
Can you explain the RC filter a little more? Do I want a notch filter at 60hz?
Thanks!
Dave
Offline PSR B1257
« Reply #3 on: August 29, 2012, 10:34:21 pm »
No, just a lowpass.
Try this circut.
The Output-Signal is inverted off course do to the open collector output of the optocoupler, but that shouldn't be a problem I think.
In theory, there is no difference between theory and practice. But, in practice, there is.
Offline David_AVD
« Reply #4 on: August 30, 2012, 12:07:58 am »
That circuit looks overly complicated.  All you need on the AC side is a series resistor and the reverse diode.  You can add a capacitor across the opto output to get rid of the ripple.  The value of the capacitor will depend on the pullup resistor value of course.  Maybe try 1uf and a 10K pullup to start with.
Offline PSR B1257
« Reply #5 on: August 30, 2012, 06:24:55 am »
That's right, there is no need for D1.
Sure, but where is the difference to have the capacitor on the one or the other side?
LT Spice gives a 3V outputripple for this RC-combination. With 22µF and 10kOhm only 300mV.
Offline David_AVD
« Reply #6 on: August 30, 2012, 07:43:32 am »
There's more than one way to do this of course.  The capacitor on the output side can often be lower voltage.  The OP can try these circuits for real and adjust R/C to taste.   :)
Offline ttp
« Reply #7 on: August 31, 2012, 04:04:44 am »
If you rectify 28Vac it will give you about 40Vdc, set a current of 5mA for the optocoupler and the power is less than 0.2W. If you add a cap to filter the DC (doesn't have to filter very good, just enough to keep the LED in optocoupler going to the next peak) you get a steady signal at the optocoupler output.
I hope you realize that using just a diode and resistor you'll get a pulse train on the output when the AC is on.
Offline David_AVD
« Reply #8 on: August 31, 2012, 05:06:13 am »
I've used 47K as the input resistor to the opto-coupler before.  A 1uF capacitor across the opto's output worked well in conjunction with the pull-up resistor on a PIC chip.
