Hello, I'm new here but have many electronics questions to come! Although I'm trying to learn electronics, my knowledge is currently very basic so I am hugely welcome to any help. I'm trying to make a small infrared LED array to support a webcam recording at night. I suffer from insomnia and have done for over 5 months now and it would help hugely to see if something is happening at night, i.e. snoring/ restless leg syndrome etc. It would seem best to either confirm or deny and possibility issues at night so I need to create a way to record myself, preferably cheaply.
I currently have a lot of components to hand, so should be able to make this up with what I've got, but I'm happy to buy anything in if needed. I'm looking to create an infrared LED array with 20 LEDs rated at 1.5-1.6v 60mA. I believe (using this calculator
http://led.linear1.org/led.wiz) I can create four rows of five LEDs with an 82 ohm resistor on each line. However, upon testing any 12v power supply (I have three to hand) I get a reading of around 16v. Does this mean that all the power supplies I have are unregulated and if so, what might be a good alternative? Could I use these or make a circuit with some sort of voltage regulation?
I have this circuit for another project, could I use this perhaps?
http://www.satisled.com/33w-power-led-driver-mr16-acdc12v-input-dc911v-600ma-output_p1066.htmlAll the webcam recording will be done on my laptop through USB so it's only the infrared array I'm worried about currently.
Thanks!
