Short version:
Trying to find if some caps I pulled off a board are ok to re-use. They are rubycon electrolytic caps.
Specific example (one of them): 35v220uF YXA. BUT...my meter reads it as a 193uF.
I'm assuming that (the YXA) is the tolerance but I cannot find ANYWHERE anything to confirm that and if it is what the values represent. Only other info on the thing is 3m1112 and 108C.
The others have the (suspected) tolerance markings as YK or ZLH
Longer version:
Don't know how to use an iron very well so practicing by scavenging parts from trashed electronics. Figure if I cook parts here while learning I don't mind. I'm learning things like how to hold it properly. How important it is to keep the tip wetted and clean. How the temp fluctuates depending on how much crud is on the tip (that was a surprise actually) and also how hot the different pieces get while heating them. Bunch of things all at once all the while getting an in depth view of how "pros" attach the bits and pieces.
Having said that, i'd like to use any parts that I can use (just to be thrifty). To that end, after pulling the part off I use my new meter to check the values against what's printed on the part to make sure it's still ok. So far so good, but I hit a bit of a wall with a bunch of capacitors I pulled off. The markings are way off what the meter is reading (I'm using the eevlog branded bryman). Unfortunately I can't tell if it's within spec or not cause I can't figure out the tolerance ratings on the things based on the markings I see. So either they're trashed or they're within tolerance. Can anyone help? Example above in the short version.
