Author Topic: Driving this dual coloured COB LED?  (Read 3466 times)
Offline LooseJunkHaterTopic starter
« on: February 02, 2023, 07:34:50 pm »
Hello, I want to use 2x potentiometers to control the brightness of the warm white (WW) & cool white (CW) LED’s (image 1; https://www.aliexpress.com/item/4000381180509.html ), but I’m not exactly sure how to drive this LED. I know that I need both CC (constant current) and CV (constant voltage) control for LED's, but since the ground is separated for this LED design, it confuses me. I’m assuming that this style (image 2; https://www.aliexpress.com/item/1005002303002760.html ) of boost converter WON’T work because the ground are commoned together??? Maybe I could get this boost converter to work if they are isolated from each other, but maybe I’m thinking about this the wrong way?
I was thinking of just using a single boost converter and then using a mosfet to limit the current of both the WW and CW LED’s, but this design is obviously nowhere as efficient as simply using two separate boost controllers.
Mosfet to limit current circuit:
What is the intended way/best way of driving an LED like this? Thanks!
« Last Edit: February 02, 2023, 07:39:19 pm by LooseJunkHater »
Offline ledtester
Re: Driving this dual coloured COB LED?
« Reply #1 on: February 02, 2023, 08:15:46 pm »
It appears that the COB LED looks like this internally:
1706974-0
The "constant current source" presented in the video operates on the low side - technically it is a constant current "sink". To control both LEDs in the COB you can use two copies of the constant current control like this:
1706980-1
Each CC control unit would have its own potentiometer.
« Reply #2 on: February 03, 2023, 05:57:18 pm »
Is there any other way to control the LED brightness aside from using the MOSFET for an inefficient constant current control?
Online Zero999
  • 0999
« Reply #3 on: February 03, 2023, 06:36:29 pm »
What's the supply voltage vs LED forward voltage?
The current needs to be controlled, not the voltage.
The LEDs being common anode doesn't help matters.
« Reply #4 on: February 03, 2023, 06:47:12 pm »
Voltage: 36-39V, current:600mA+600mA. I understand that the LED needs current control.
Online Zero999
  • 0999
« Reply #5 on: February 03, 2023, 07:30:12 pm »
Is that the supply, or LED forward voltage?
« Reply #6 on: February 04, 2023, 07:03:23 pm »
No idea, I'm listing what's on the AliExpress page that I had listed above.
« Reply #7 on: February 04, 2023, 07:36:04 pm »
So I thought this up last night before falling asleep, but would this work (as seen in the image)?
Having the voltage boosted to around 37V (absolute max of XL4015 is 40v) and then using the constant current function of the XL4015 to limit the current flowing through each individual LED and using the constant current pot on the XL4015 module to control the brightness?
In my head it seems like this would work but I'm not sure? What may be the problem of this design?
Product link: https://www.aliexpress.com/item/1937996219.html
Edit: This LM2596HVS module supports 50V and appears to support constant current as well, for those worried about the max voltage of the XL4015? https://www.aliexpress.com/item/1005005083519953.html
« Last Edit: February 04, 2023, 07:39:04 pm by LooseJunkHater »
Offline timenutgoblin
« Reply #8 on: February 04, 2023, 09:27:51 pm »
The LM2596HVS has a minimum input voltage requirement of 4.5V which means that if you have your COB LED connected in series with a forward voltage of 36V then the boost converter will need to be outputting >40.5V to support the operation of the COB LED.
You may need a boost converter with a higher output voltage capability.
« Reply #9 on: February 05, 2023, 12:30:49 am »
Since the LM2596HVS has a minimum output voltage of 1.2V, you will need to connect a load resistor to complete the circuit otherwise the COB LED won't work. It might flash briefly, but won't stay on. Since the COB LED has a forward current of 600mA, you will need a 2 ohm 1W-rated resistor connected at the output of the LM2596HVS buck converter. Either a pair of 1 ohm resistors in series or a 2.2 ohm and 22 ohm resistor in parallel should work.
« Reply #10 on: February 05, 2023, 04:32:19 am »
Woops, didn't even consider a minimum input voltage for the buck converter. However taking that into consideration, should I go the route of using a boost converter and then constant current buck converters (very complex and more to fail), or instead a mosfet (simpler but likely less efficient?) for constant current regulation? Maybe someone could help me with efficiencies math, since I'm not good with math.
What sort of power dissipation should I expect if using a mosfet for use of constant current regulation of a 25W LED? No idea how I'd do the same calculation for the buck converter?
Online Zero999
  • 0999
« Reply #11 on: February 05, 2023, 09:44:56 am »
No, connecting the LEDs between the output of a boost and input of a buck converter won't work. A buck converter doesn't work like that. A buck converter regulates the output, not input current. A current limited buck converter with a short circuited output will hardly draw any current from the input. If the output of the buck is tied to 0V like that, the input current will be very low.
The LED needs to be connected to the output, not the input of the buck converter. You could put a MOSFET in the negative of each LED, each driven with the opposite signal, so either one LED is on, or the other. If you need to turn them both on, then PWM at 50%
You still haven't stated your power supply voltage. It's pretty important to know that, before going any further.
Offline mariush
« Reply #12 on: February 05, 2023, 10:34:47 am »
Ok.... easiest would be to get a power supply that outputs more than the forward voltage of the leds, and then use a  couple  BUCK led drivers to control the current going through each led, using a potentiometer for each driver.  Or you could use a dual potentiometer  / stereo potentiometer (but these are logarithmic so the brightness won't change as linearly)
The page says 36-39v forward voltage, up to 600 mA for each led ... but knowing the quality of leds on Aliexpress I'd say don't go over 450-500mA ... anyway.
Example of step-down / buck led drivers :
AL8862 : https://www.digikey.com/en/products/detail/diodes-incorporated/AL8862QSP-13/10670150
max 55v in, 1A  0.4v .. 2.5v on CTRL pin to adjust brightness (so a potentiometer and a resistor to form a voltage divider and you're good.
ILD6150 : https://www.digikey.com/en/products/detail/infineon-technologies/ILD6150XUMA1/4897530
max 60v, 1.5A ... same deal, you can set max current with the Rsense resistor and then use a potentiometer to adjust brightness
Datasheets contain example circuits with values of components, example application circuits..
Let's say you need at least 42v and 1.2A so a total of 50 watts.
Easiest to obtain that would be by either with a 48v power supply (you can adjust the output voltage a bit to bring it down a bit for less losses if needed) or by making your own power supply using a classic transformer.
For example find a toroidal transformer or a classic transformer with two 18-24v AC secondary windings (or a single 36-48v secondary winding), add a bridge rectifier and a big capacitor on the output and you have your 42v+ power supply. If you want to get the full 50w on the led, you'll need at least a 75VA or higher transformer, otherwise you could go with a 50 VA transformer (and expect maybe 400mA on each led, still quite bright)
Here's some examples :
50w toroidal for 18$ https://www.aliexpress.com/item/1005004459527878.html
100w toroidal for 28$ https://www.aliexpress.com/item/1005004459735891.html
A bridge rectifier converts AC voltage to DC voltage, and result is a DC voltage with a peak  equal to Vdc peak = 1.414 x Vac - 2 x voltage drop on rectifier diodes.
So for example, with 18v AC secondary windings for a total of 36v AC  you would get  Vdc peak = 1.414 x 36v - ~ 2v  = 49v DC peak.
Now you determine how big of a capacitor to use to keep the minimum voltage always above some threshold, let's say 42v in our case ...
C  =  Current /  ( 2 x AC frequency x (Vdc peak - Vdc min) )  =  1.2 A / 2 x 60 x (49 - 42)  = 1.2 / 120x7  = 0.00142857 Farads or 1428.6 uF  ... so you'd need at least a 1500uF 63v rated capacitor to keep the voltage above 42v all the time.  I'd use 2200-3300uF.
Online Zero999
  • 0999
« Reply #13 on: February 05, 2023, 11:27:46 am »
They almost certainly won't be designed for both LED strings to be operated at full power simultaneously.
The trouble is, the LEDs are common anode, which makes them incompatible with those drivers, because they both have the sense resistor in the positive line.
« Reply #14 on: February 05, 2023, 11:50:56 am »
This COB LED is a common anode design which requires a current sink to drive them independently, as opposed to a current source like you're describing. If the buck converter (CC module) is connected between the boost converter output and the common anode, it will not be possible to independently regulate the current in each LED string. The buck converter (CC module) needs to be connected between the cathode and ground to independently regulate the current in each LED string.
Alternatively, it's possible to power the COB LED using a negative voltage or negative current source. If the common anode is connected to ground and a negative voltage is applied to the cathodes then that should work.
Common anode to ground and -36V to each cathode at 500mA (as @mariush suggested).
Online Zero999
  • 0999
« Reply #15 on: February 05, 2023, 12:25:11 pm »
I wasn't suggesting controlling them independently. Use one buck converter and connect the LEDs to the output via MOSFETs and switch them alternately. The LEDs won't be able to take the full current simultaneously on both channels anyway.
Using two of the buck converter modules suggested by the OP won't work, because they're current sources and the LED is common anode.
Now go and find a buck converter module with a negative output current.
The following users thanked this post: spostma
Offline Psi
« Reply #16 on: February 05, 2023, 12:26:44 pm »
MEANWELL have some mains input CC led drivers that will do 36V leds.
And some have 3 types of brightness control input,  0-10V, PWM or external potentiometer.
Check out something like this one for $28
https://www.digikey.com/en/products/detail/mean-well-usa-inc/XLG-50-AB/9858488
« Last Edit: February 05, 2023, 12:36:47 pm by Psi »
Online Zero999
  • 0999
« Reply #17 on: February 05, 2023, 02:21:54 pm »
I've used those type of of Meanwell LED drivers before and they're good.
It's definitely an option, if it's running off the mains. It has an isolated output, so the LEDs being common anode isn't a problem. I'd probably choose a lower current model though, as the LEDs will smoke if both are run at 530mA simultaneously.
« Reply #18 on: February 05, 2023, 06:17:15 pm »
You're right. I plan to use this module [https://www.aliexpress.com/item/1005002303002760.html] to create the main ~36-40V input. It can output up to 50v.
I have 0 intention of using this COB LED at full power for most of its life as I'm aware that LED's are less efficient when being driven harder plus their lifespan significantly decreases.
This is a brilliant idea but unfortunately from my research creating above -15 volts with constant current control for cheap is quite difficult (and expensive).
Another great idea but sadly for me (I didn't mention this earlier; my apologizes) I plan to make it a portable light likely running off of high power lithium cells (hence the boost converter).
___
Based off of everything that I've read so far it seems like my idea of using a mosfet for constant current control is the simplest and cheapest idea as it seems like the other ideas listed so far either won't work (like my buck converter idea) or are more expensive than I'd like?
Could I maybe get some help with calculating how much power I expect each mosfet to dissipate?
Online Zero999
  • 0999
« Reply #19 on: February 05, 2023, 07:13:16 pm »
What's wrong with my suggestion? The MOSFETs will hardly dissipate any power, above the on resistance, multiplied by the current. If both LEDs are required to be on simultaneously, PWM the input at 50% duty cycle, which will make each half as bright, but won't change the overall brightness, just the colour temperature. You'll now be able to set the brightness by changing the buck converter's current and the colour temperature by PWM.
If you go for a boost converter+linear current sink, then the power dissipation in the transistors will simply equal the current, multiplied by the voltage drop. Set the voltage of the boost converter to a little over the voltage dropped by the sense resistor + LED + transistor. If it's just a one-off, then you could find out the actual LED forward voltage, at the desired current, rather than relying on the worst case, given on the data sheet. I wouldn't bother with a MOSFET, because it's prone to oscillation. A power transistor with a high enough hFE such as the BD131 will be able to sink enough current, when driven with the LM358.
« Reply #20 on: February 05, 2023, 07:45:07 pm »
To be honest, I don't quite understand how your circuit works. What's controlling the "input" of the mosets? If it's more efficient and still relatively simple, I love it. I'm not an expert on EE (hence why I'm posting in the "beginner" section).
Online Zero999
  • 0999
« Reply #21 on: February 05, 2023, 08:22:08 pm »
The input just controls which MOSFET turns on. A1 is a NOT gate, but it doesn't have to be an actual gate. It was just to show the opposite signal must be applied to M2's gate, to M1's gate. This means both LEDs can't be on simultaneously, but that doesn't matter. If you want both on, just flick between the two at a high enough frequency, they eye won't be able to tell, so they'll both appear on.
Thinking about this again, it might be simpler to just do with the boost converter+linear current sink. That would save having to have another buck converter module and if the voltage from the boost converter is kept low enough, it'll achieve comparable efficiency.
« Reply #22 on: February 05, 2023, 09:14:49 pm »
Just for my own knowledge and growing, what is the input controlled by? A microcontroller? How would that provide constant current control (I guess it wouldn't?). I understand the part of frequency + duty cycle for brightness control.
Online Zero999
  • 0999
« Reply #23 on: February 05, 2023, 09:53:27 pm »
A microcontroller is one way, but the old 555 timer will also work. Another transistor could be used to make the NOT gate.
The constant current symbol represents the output of your current limited buck converter module, which presumably is controlled with a potentiometer.
Offline Psi
« Reply #24 on: February 05, 2023, 10:41:43 pm »
MEANWELL won't let you off that easy, they have a step-up DC input option for that too.   :-DD
Input 12V  (9-18V range)
Output up to 43V LED
CC 1.05A (a little under your 1.2A LED spec, but that's good, the LED will have a good lifespan not being driven right on the edge of failure/running hot)
Power 45W
Analog input for brightness control (I think on these ones you need couple resistors and regulated source to get the pot to produce a 0.25V to 1.3V signal. (unlike that previous one that can take pot directly on pins)
91% efficient.
Even cheaper, $21
Check out this one
https://www.digikey.co.nz/en/products/detail/mean-well-usa-inc/LDH-45A-1050W/7704776
Datasheet
https://www.meanwellusa.com/upload/pdf/LDH-45(DA)/LDH-45-spec.pdf
MEANWELL have a huge range of modules, i only looked for a minute so there might be ones that can do 1.2A if you spend some time looking.
The LDH-65-1400 maybe, it does 1.4A, but you could hardware limit it to 1.2A avg by limiting the max scale of the brightness control voltage.
$28
https://www.digikey.co.nz/en/products/detail/mean-well-usa-inc/LDH-65-1050W/12759739
« Last Edit: February 05, 2023, 10:55:21 pm by Psi »
