Author Topic: driving two LMZ14201 by using LM3880 with Mosfet  (Read 651 times)
Offline BeOTopic starter
« on: July 07, 2018, 10:46:40 am »
Hello
I need to drive two LMZ14201 in sequence
I will try to test this schematic updated with two Mosfet to drive the EN pin and one p Chanel to put the EN pin to the ground
P Mosfet  will ground through a resistor to force LMZ14201 to 0 V output
N Mosfet will power the EN pin to 5 V
and vise versa following flag level ( flag is in 5 V )
can someone can give an advice on this schematic
I will set one circuit per LMZ14201
Regards
BeO
« Last Edit: July 07, 2018, 01:13:30 pm by BeO »
