Yes I guess that's what I will be doing. So long as I don't blow things up in the process. The capacitance I'm using is 2 X 10000uf 63 volt electrolytic capacitors. That should be ok for 10 Amps at 13.80 volts. I am tempted to remove secondary windings, but don't want to mess up a perfectly good toroidal transformer. If it had a single winding, I probably would have done it by now. But twin secondary windings is a bit more daunting.
