I haven't loaded it down yet, after the rectifier and filter capacitors. It's a 300 VA toroidal transformer, rated at 18.00 Volts. I have previously used two 300 VA toroidal transformers for another power supply, they where rated at 12.00 Volts. They sagged very little with a 200 watt load. I don't have an electronic load at the moment. All I know is I need 13.80 Volts at 10 Amps maximum, although the actual current drawn will be closer to 8 Amps when running HF radio equipment. So it won't be a continuous load, more like a 50% duty cycle. When I have measured the mains where I live, many times over the years, I've never seen a reading lower than 240 Volts. This is a single very high power transistor, it's a Darlington rated at 50 Amps 300 watts. I wanted to see if I can get a linear power supply, to produce 10 Amps at 13.80 Volts with a single transistor. I'm not sure what to do with this 300VA 18.00 Volt transformer. I hoped to avoid removing windings, it never as tidy after doing that. I suppose I must find a load equivalent to 10 Amps to see what that rectified and filtered 27.00 Volts secondary drops to with a 10 Amps load. I can't use lamps unless I connect them in series, and then in parallel. Just parallel would blow them. The power resistor sounds like an interesting way of dropping power, although I imagine it would produce loads of heat. And would have to be a metal clad resistor bolted to a suitable heat sink. Now I think of it in terms of the voltage drop under a 10 Amp load, it might be ok, as you say, that 27.00 volts should drop considerably.
