Author Topic: Coomon Cap + Resistor Values  (Read 2654 times)
Offline echen1024Topic starter
  • 15 yo Future EE
« on: November 03, 2013, 04:21:54 am »
Well, I'm about to stock up again at Digi-Key, so I wanted to know what value resistors and caps I should get, and are just good to have around. Any other components are welcome as well. I do have an extensive 74 series collection, so keep that in mind.
I'm not saying we should kill all stupid people. I'm just saying that we should remove all product safety labels and let natural selection do its work.
https://www.youtube.com/user/echen1024
Offline rexxar
    • Forever Tinkering
Re: Coomon Cap + Resistor Values
« Reply #1 on: November 03, 2013, 06:43:39 am »
This question has been asked before.
A lot of the advice given around here is to just buy what you need for your current project, plus five or ten to go in your parts collection. Beyond that, you could try ordering values from the E12 series, or maybe E24 if you have the space and budget.
Since you're in the US, Radioshack sell a big pack of assorted resistors for about $17, IIRC. I don't remember exactly what's in it, but they're all fairly common values. They don't have much in the way of caps, though, so you'll have to order those.
Offline Stonent
« Reply #2 on: November 03, 2013, 08:56:56 am »
Well from what I've seen most resistors and caps come in these multiples (commonly)
1's (1,10,100,1k,10k,100k,1M,10M etc)
2.2's (2.2, 22, 220 etc)
3.3's (and so on)
4.7s (and so on)
Also, if you haven't checked already, give Tayda a look. I ordered all this for about $25 including shipping (the end number is the quantity)
NE555 IC 555 Timer DIP-8	A-249	5
Coin Battery Holder CR2025 and CR2032 A-869 10
Stackable Header 6 Pins 2.54mm A-1048 10
2N3055 NPN AF Amp Audio Power Transistor 15A 60V A-110 1
2N2222A 2N2222 NPN Transistor 0.8A 40V TO-18 A-113 2
2N2907A 2N2907 PNP Transistor 60V 0.6A TO-18 A-115 2
LED UV 5mm Ultraviolet A-1155 10
32.768 kHz Crystal Cylender 3 x 8 mm A-1592 5
10 OHM 1/4W 1% Metal Film Resistor A-2198 10
100 OHM 1/4W 1% Metal Film Resistor A-2245 10
100K OHM 1/4W 1% Metal Film Resistor A-2248 10
10K OHM 1/4W 1% Metal Film Resistor A-2203 10
10M OHM 1/4W 1% Metal Film Resistor A-2287 10
1K OHM 1/4W 1% Metal Film Resistor A-2200 10
1M OHM 1/4W 1% Metal Film Resistor A-2277 10
2.2K OHM 1/4W 1% Metal Film Resistor A-2341 10
22 OHM 1/4W 1% Metal Film Resistor A-2345 10
220 OHM 1/4W 1% Metal Film Resistor A-2246 10
220K OHM 1/4W 1% Metal Film Resistor A-2329 10
22K OHM 1/4W 1% Metal Film Resistor A-2284 10
4.7 OHM 1/4W 1% Metal Film Resistor A-2308 10
4.7K OHM 1/4W 1% Metal Film Resistor A-2310 10
4.7M OHM 1/4W 1% Metal Film Resistor A-2357 10
47 OHM 1/4W 1% Metal Film Resistor A-2190 10
470 OHM 1/4W 1% Metal Film Resistor A-2247 10
470K OHM 1/4W 1% Metal Film Resistor A-2180 10
47K OHM 1/4W 1% Metal Film Resistor A-2279 10
3.3 OHM 1/4W 1% Metal Film Resistor A-2189 10
3.3M OHM 1/4W 1% Metal Film Resistor A-2356 10
33 OHM 1/4W 1% Metal Film Resistor A-2286 10
330 OHM 1/4W 1% Metal Film Resistor A-2325 10
330K OHM 1/4W 1% Metal Film Resistor A-2330 10
33K OHM 1/4W 1% Metal Film Resistor A-2290 10
MPSA64 Darlington Transistor PNP A-893 5
MPSA13 Darlington Transistor NPN A-432 5
PN2222A PN2222 Transistor NPN 40 Volts 600 mA A-109 20
PN2907A PN2907 2907 PNP 60V 0.8A Transistor A-108 20
BC550 NPN Low Noise Transistor A-213 5
BC560 BC560B Low Noise Transistor PNP A-901 5
MPSA42 NPN High Voltage Transistor 0.5A 300V A-288 5
MPSA92 PNP High Voltage Transistor 0.5A 300V A-136 5
LM317T LM317 Voltage Regulator IC 1.2V to 37V 1.5A A-177 4
LM7805 L7805 7805 Voltage Regulator IC 5V 1.5A A-179 4
LM317LZ LM317L LM317 0.1A Voltage Regulator IC A-500 8
L78L05ACZ L78L05 78L05 +5 VOLTS 100mA Voltage Regulator IC A-176 10
1nF 0.001uF 100V 5% Polyester Film Box Type Capacitor A-557 1
10nF 0.01uF 100V 5% Polyester Film Box Type Capacitor A-559 1
100nF 0.1uF 100V 5% Polyester Film Box Type Capacitor A-564 1
4.7uF 35V 105C Radial Electrolytic Capacitor 5x11mm A-4504 2
33uF 50V 105C Radial Electrolytic Capacitor 6x11mm A-4549 2
0.1uF 50V 105C Radial Electrolytic Capacitor 5x11mm A-4531 2
1uF 50V 105C Radial Electrolytic Capacitor 5x11mm A-4505 2
2.2uF 100V 85C Radial Electrolytic Capacitor 5x11mm A-4511 2
0.47uF 50V 105C Radial Electrolytic Capacitor 5x11mm A-4516 2
3.3uF 100V 105C Radial Electrolytic Capacitor 6x11mm A-4508 2
10uF 35V 105C Radial Electrolytic Capacitor 5x11mm A-4548 2
100uF 16V 105C Radial Electrolytic Capacitor 5x11mm A-4514 2
22uF 50V 105C Radial Electrolytic Capacitor 5x11mm A-4530 2
0.22uF 50V 105C Radial Electrolytic Capacitor 5x11mm A-4512 2
47uF 16V 105C Radial Electrolytic Capacitor 5x11mm A-4522 2
220uF 25V 105C Radial Electrolytic Capacitor 8x11mm A-4503 2
330uF 16V 105C Radial Electrolytic Capacitor 6x11mm A-4553 2
470uF 16V 105C Radial Electrolytic Capacitor 8x11mm A-4521 2
1000uF 16V 105C Radial Electrolytic Capacitor 10x16mm A-4523 2
1pF 50V Ceramic Disc Capacitor A-507 10
10pF 50V Ceramic Disc Capacitor A-519 10
100pF 50V Ceramic Disc Capacitor A-531 10
1000pF 50V Ceramic Disc Capacitor A-543 10
4.7pF 50V Ceramic Disc Capacitor A-515 10
33pF 50V Ceramic Disc Capacitor A-525 10
2.2pF 50V Ceramic Disc Capacitor A-511 10
3.3pF 50V Ceramic Disc Capacitor A-513 10
74HC02 7402 Quad 2-input NOR Gate IC A-921 2
74HC00 7400 Quad 2-input NAND Gate IC A-920 2
74HC14 7414 HEX SCHMITT INVERTER CMOS TTL IC A-248 2
M74HC595B1R 74HC595 74595 8 bit Shift Register IC A-024 5
TJM4558 4558 Dual Operational Amplifier Wide Band IC A-1132 2
LM358N LM358 358 Low Power Dual Op-Amp IC A-045 2
TL082 TL082CN J-FET DUAL OP-AMP IC A-209 2
LM324N LM324 324 Low Power Quad Op-Amp IC A-046 2
TL064 Quad Operational Amplifier J-FET PDIP-14 TL064CN A-1134 2
HA17741 17741 IC OPERATIONAL AMPLIFIER A-280 2
9V 9-Volt Battery Clip / Connector Snap A-656 5
5mm Bezel LED Holder Chrome Metal A-660 4
LED 5mm Red Super Bright A-1554 33
Small StripBoard 94x53mm (Copper) A-5031 1
Offline c4757p
  • adieu
« Reply #3 on: November 03, 2013, 11:25:11 am »
For a more evenly spaced resistor series: 10 18 33 56 (each is 1.8 times the last, including 56 -> 100). That way you are more likely to have the value you want.
You could do 10 20 30 39 as well, making it easy to stack a few in series to get the value you want, if you don't mind stacking them.
I actually just bought a cheapo E24 pack on eBay, then tested which were not within tolerance and bought those on my next Mouser order. I specify SMD resistors at E24, so I want the same set for prototyping.
