Author Topic: On the search for SRAM chips for the Z80.  (Read 15736 times)
Offline PA0PBZ
Re: On the search for SRAM chips for the Z80.
« Reply #25 on: October 24, 2013, 09:21:02 am »
But hey, the schematic would work-right?
The problem is that you are making it very hard to verify what it does, compare your drawing with this:
Offline makerimagesTopic starter
  • Country: ee
« Reply #26 on: October 24, 2013, 10:26:46 am »
That is indeed more readable-I agree. But.. is there an Eagle library for individual logic gates?
Offline PA0PBZ
« Reply #27 on: October 24, 2013, 10:46:16 am »
I don't have/use Eagle but it looks like it is possible:
Offline daveshah
  • Country: at
    • Projects
« Reply #28 on: October 24, 2013, 01:36:00 pm »
The 74xx-US, 74xx-EU and 40xx libraries (should be included in your Eagle installation) have parts split up into individual logic gates. Once you have placed the part, use the invoke tool (or right click and select Invoke) to place the remaining gates and power symbol - remember not to forget the power connections!
  • Country: ee
« Reply #29 on: October 25, 2013, 08:46:58 am »
Oh really? Great!
  • Country: ee
« Reply #30 on: November 03, 2013, 10:26:13 am »
Allright, ordered the parts I need to start off with from 2 suppliers-one order is useless without the other!
Now, I wrote a small piece of asssembly code to practice with
Start:
 .ORG 000h
 LD A,5
 LD B,A
.end
.end
Using tasm301 I got this .LST file https://www.dropbox.com/s/fmtij3zcwir4szx/TRY.LST
format:
Line  Address Data Source
And now I face a challenge-at first I would like to bitbang the .LST file to the memory chip. What puzzles me is the
0003   0000 3E 05        LD A,5
line, 3E and 05 make a 16 bit value, z80 has 8 data bits-3E fits, 05 doesn`t, what I want to know is where the 05 would go. My guess is it goes to 0001 of memory. Am I right?
  • Country: ee
« Reply #31 on: November 03, 2013, 11:10:04 am »
So this is how I would bitbang it?
address                            data
0000000000         00111110
0000000001         00000101
0000000010         01000111
  • Country: ee
« Reply #32 on: November 03, 2013, 12:38:50 pm »
hmm, there is still one thing. From what I know there is this indianness, beign big or small, I believe the z80 uses big, what does that mean to me, which end of address goes to a0 and which end of data goes to db0?
Offline grumpydoc
« Reply #33 on: November 03, 2013, 01:03:56 pm »
Z80 is little-endian so the least significant byte of a multi-byte value goes at the lower address, so a jump to address 0x1003 will appear as
C3 03 10
in a hex dump of memory
  • Country: ee
« Reply #34 on: November 03, 2013, 01:22:41 pm »
so basically I can do. a raw hex to bin conversion, add 0s in the beginning to form a byte and then just have the result going to the db from left being db0 and right end. db7, same with addresses? so the binary above is valid to enter from left to right
Offline grumpydoc
« Reply #35 on: November 03, 2013, 02:03:22 pm »
Not quite
Your byte order is OK
Your bit order is correct as you have written it out.
Your bit order is wrong, however in your description above. d0 on the data bus is the least significant bit. When you write this out you will have bit 7 on the left and bit 0 on the right
IE:
address            hex    binary
                         D7    D0
0000000000         3E    00111110
0000000001         05    00000101
0000000010         47    01000111
  • Country: ee
« Reply #36 on: November 03, 2013, 02:19:21 pm »
and address line?
Offline grumpydoc
« Reply #37 on: November 03, 2013, 03:32:18 pm »
A0 is least significant
  • Country: ee
« Reply #38 on: November 03, 2013, 03:35:30 pm »
so that is reversed above aswell?
