Author Topic: Help needed with I2C LCD + Arduino - DS-LCDD5  (Read 2929 times)
Offline jdev99Topic starter
Re: Help needed with I2C LCD + Arduino - DS-LCDD5
« Reply #25 on: October 27, 2021, 02:17:28 pm »
just for interest: what chip do you have on your i2c backpack?
It is a PIC18F13K22.  Should definitely handle 100kHz I2C.
Offline DrG
« Reply #26 on: October 27, 2021, 02:41:16 pm »
That's the part that is no fair. The data sheet that you posted lists the max I2C speed at 400kHz and no minimum. I have used chips that told you that 50kHz was the max I2C speed (even 10kHz during initialization), but telling you it's good to go at 400kHz and then...... no fair.
BTW: I wonder why the scanner found it - does that one use a variety of I2C speeds?
- Invest in science - it pays big dividends. -
Offline HB9EVI
« Reply #27 on: October 27, 2021, 03:07:19 pm »
hm, a PIC on that place I didn't meet yet; more chips like PCF8574A; strange
« Reply #28 on: October 27, 2021, 05:10:52 pm »
Yes, those PCF8574A are the usual ones, this one was made by a UK company, Designer Systems . The data sheet is with my 1st post.
