Author Topic: Dual 555 Timer (with inverted signal) for H Bridge Problem  (Read 2335 times)
Offline z7d8tsgTopic starter
I tried this circuit but it doesn't work. Any thoughts?
Thanks,
- Dan
Offline David Cutcher CEG
Re: Dual 555 Timer (with inverted signal) for H Bridge Problem
« Reply #1 on: May 15, 2019, 11:49:12 pm »
You say "H Bridge problem."
You need to be more specific.
What is the problem?
Is this a problem for school?
What is the expected output?
Not enough information here for me to attempt a helpful answer.
David Cutcher "Certified Evil Genius"
« Reply #2 on: May 16, 2019, 12:22:20 am »
im building an h bridge that uses 2x 555 timer with optocoupler non zero gate crossing (k3011p). It needs to run off of 1x power supply at the end, I will be using voltage regulators to regulate voltage and resistors to split amperes properly. Is for a high accuracy remote car
Best,
- Dan
« Reply #3 on: May 16, 2019, 05:12:49 am »
The original circuit, attached, should work. I'm uncertain about where your added lines are connected.
Also, as noted on the circuit, this is using a split voltage. You don't indicate that on yours.
Offline soldar
« Reply #4 on: May 16, 2019, 07:50:40 am »
That circuit could have some serious shoot-through problems.
Online Zero999
  • 0999
« Reply #5 on: May 16, 2019, 09:38:22 am »
That will work, but not very well. There will be a huge voltage drop of about 6V, given a current draw of a couple of Amps, because of the Darlington pair configuration and the 555's output stage drops over a Volt, on the high side.
« Reply #6 on: May 16, 2019, 01:00:10 pm »
How can I make a potentiometer change the frequency while keeping the duty cycles at 50% for both pwm signals?
Offline malagas_on_fire
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #7 on: May 16, 2019, 01:11:52 pm »
Another space improved idea is using a 556 which consists a chip with two 555 timers sharing the same power source :P.  Drive the mosfets with some transistors between the 555's and the Gate's, "doodle" something for "H bridge DC motor. ".
PS: I'm making an assumpcion on driving improperly the H bridge , but more data would be good to assist .
« Last Edit: May 16, 2019, 01:20:59 pm by malagas_on_fire »
If one can make knowledge flow than it will go from negative to positve , for real
Online Zero999
  • 0999
« Reply #8 on: May 16, 2019, 01:44:33 pm »
The classic is to use the 7555, instead of the normal 555.
A 555 timer isn't the best circuit to use to get 50% duty cycle. I've built the above circuit and it didn't give a perfect 50% duty cycle output. It's better to use an oscillator and divide by two counter. The CD/HEF4013 work quite well.
