Author Topic: Connecting PCBs together  (Read 3143 times)
Offline JacksterTopic starter
    • PCBA.UK
« on: March 04, 2017, 07:44:51 am »
Hi all.
Bit of an odd one. I need advise on connecting PCBs together like in a "H" arrangement.
I basically require 3 PCBs, 2 vertical and one horizontal.
The horizontal would need to connect to the two vertical ones either side.
What method is best for this?
I am thinking I need some tolerance with this. Not a lot but some.
Thanks
Jack,
Offline Richard Crowley
  • KJ7YLK
Re: Connecting PCBs together
« Reply #1 on: March 04, 2017, 07:58:00 am »
Size?
Number of pins?
Permanent or pluggable?
My first thought was something like....
    • PCBA.UK
« Reply #2 on: March 04, 2017, 08:04:01 am »
Size?
Number of pins?
Boards are all 25x50mm.
Pins from 4 to 10.
Permanent.
Was thinking something along those lines.
Offline Avacee
« Reply #3 on: March 04, 2017, 09:16:10 am »
Not sure if this matches your requirements but Mike shows one solution in this video - go to 8:17
Offline Rudane
    • Electrical Engineering 101
« Reply #4 on: March 04, 2017, 08:07:00 pm »
Depends on the environment. If you are doing this at home for a hobby, what's suggested is fine. If you are moving to a design you plan to sell, consider that a solder joint is not meant for mechanical stability and using fasteners would be a better option.
Voltage appears across and current flows through.
Offline Electro707
« Reply #5 on: March 04, 2017, 08:59:08 pm »
If they are far apart where you can't connect them with pin header i recommend either ribbon cable or something along those lines.
