Author Topic: Transistors  (Read 2228 times)
Offline Rihards VeipsTopic starter
  • Country: lv
Transistors
« on: April 04, 2014, 09:01:03 pm »
Is there a way to multiplex transistors[NPN] like an LED cube?{With an Arduino} (Can't figure out how it would work with transistors)
       I need that for my lighting project to drive ~64 relays     o-o
[3x3x9 Transistor Tower]
« Last Edit: April 04, 2014, 09:17:31 pm by Rihards Veips »
- Le Nub
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: Transistors
« Reply #1 on: April 04, 2014, 09:06:41 pm »
err 3x3x9 is not a cube.
You give practically no detail of what you are trying to do. how do you want to control it ? this sounds like a need for an mcu driving a multiplexer driving a bank of latches
  • Country: lv
Re: Transistors
« Reply #2 on: April 04, 2014, 09:24:42 pm »
I think I figured it out - I connect all the BASE pins in collumns and the collumns on the output pins of the Arduino    then connect the COLLECTOR to the GROUND pin on the Arduino   And if I am using a different power source for the relays I connect the negative to the ground of the transistor and the relay input to the EMMITER and the positive to the relay with a diode and a resistor.
- Le Nub
Offline mariush
Re: Transistors
« Reply #3 on: April 05, 2014, 12:31:29 am »
I don't understand what you're trying to do. I don't know what you mean by relays.. if you mean the classic mechanical relays, those aren't really designed to work like leds, to be turned off and on several times a second (not to mention it will be very noisy)
If you want to make a LED cube, here's some videos that might help you out:  https://www.youtube.com/playlist?list=PL0JWuCHXfJ2zXVRqFRFVq-lNt_xtCYMjx
In some of those videos he explains the theory behind it, the circuit, everything.
Offline David_AVD
Re: Transistors
« Reply #4 on: April 05, 2014, 12:44:21 am »
If you only want one relay on at a time, you could multiplex the drives in theory.  In practice I doubt if would be worth it due to the extra diodes required to stop the interaction between rows and columns.
Just use 8 octal driver chips such as the UCN5821.  They can drive the relays directly, have the back-EMF diodes inside and can be cascaded to simple serial control.
