Author Topic: EAGLE Newbie problem - pins not there?  (Read 1811 times)
Offline sci4meTopic starter
    • sci4me.com
« on: June 17, 2015, 02:57:11 pm »
Hey guys! So I am trying to learn to use Eagle. I quickly ran into this problem: there don't seem to be power pins on parts? Screenie:
Running ERC whines about lack of Vcc and GND connections. I would connect them if I knew how! :P
How do I deal with this?
Offline matseng
    • My Github
Re: EAGLE Newbie problem - pins not there?
« Reply #1 on: June 17, 2015, 03:05:57 pm »
Click on the Invoke -button. It looks like four small AND-gates.
On the popup menu select the line with power.
The invoke is also used for adding the other gates in multigste devices like hex inverters and others.
Offline 128er
« Reply #2 on: June 17, 2015, 03:07:47 pm »
Ah, matseng was faster :D
Or right click on the symbol you added in your schematic and klick invoke. Doesn't matter how you do it.
    • sci4me.com
« Reply #3 on: June 17, 2015, 03:31:21 pm »
Wait, does this mean I have to have the power pins separate from the chip?
I mean, I guess it makes sense and in larger designs is probably better to have a power section... but... it's kind of annoying you don't seem to get to choose.
Anyway, thanks!
EDIT: Can I fix the un-readability of the VCC and GND labels?
« Last Edit: June 17, 2015, 03:34:03 pm by sci4me »
Offline Yansi
  • STM32, STM8, AVR, 8051
« Reply #4 on: June 17, 2015, 03:34:51 pm »
Rotate it by 90 degrees.
    • sci4me.com
« Reply #5 on: June 17, 2015, 03:39:08 pm »
180*? :P
Thanks guys!
« Last Edit: June 17, 2015, 03:47:33 pm by sci4me »
