Electronics => Beginners => Topic started by: sci4me on June 17, 2015, 02:57:11 pm
Hey guys! So I am trying to learn to use Eagle. I quickly ran into this problem: there don't seem to be power pins on parts? Screenie:
(http://i.imgur.com/M04GkLO.png)
Running ERC whines about lack of Vcc and GND connections. I would connect them if I knew how! :P
How do I deal with this?
Click on the Invoke -button. It looks like four small AND-gates.
On the popup menu select the line with power.
The invoke is also used for adding the other gates in multigste devices like hex inverters and others.
Ah, matseng was faster :D
Or right click on the symbol you added in your schematic and klick invoke. Doesn't matter how you do it.
Wait, does this mean I have to have the power pins separate from the chip?
I mean, I guess it makes sense and in larger designs is probably better to have a power section... but... it's kind of annoying you don't seem to get to choose.
Anyway, thanks!
EDIT: Can I fix the un-readability of the VCC and GND labels?
(http://i.imgur.com/wGDVbST.png)
Rotate it by 90 degrees.
180*? :P
Thanks guys!
