First issue sorted, thanks very much.
On the second issue:
Supply is 10V sharp directly from spindle drive (the device this PWM converter is supposed to feed 0-10V into), and manual for it says max 10mA. I had this spindle drive/controller run the motor directly through a pot (nothing connected to it except the motor), and current at the pot doesn’t register on my meter (<1mA)
When PWM board is connected and motor starts, current barely registers 1mA.
Voltage under load:
very slow ramp up to 8V
very slow ramp down to 2.8V
Voltage no load (0-10V feed to drive disconnected):
quick ramp up to 10V
quick ramp down to 2.8V
I don’t know why the current condition drifted a bit from the original, I haven’t done anything to it except replace a variable resistor with a fixed resistor of the same value (the one immediately after the 5V supply). It’s on the other side of the optocoupler anyway, the problem must be on the 10V side. I can't think of anything other than that.
@LukeW Thanks for the suggestion. Your circuit doesn't look complicated, except when I have to troubleshoot it
I'm a beginner after all. Specified opamp was a TS912N, I've put in a TS912AIDT. Any problems here?
Not practical to supply more than 10V, I've got to work with that.
