Author Topic: Hp3582a CRT to convert to LCD  (Read 2099 times)
Online squadchannel
  • Country: jp
  • deepl translate user
Re: Hp3582a CRT to convert to LCD
« Reply #25 on: December 19, 2024, 11:13:25 am »
Sorry, I determined from the front panel bezel that it was a 1345A, but apparently not. :palm:
lcd drawing from XYZ, would need a high speed ADC.
XY is just voltage vs XY position, Z is luminance.
You can draw with a regular scope; if you input in XY mode, you will see the same thing. can't input the Z signal, the luminance will be constant.
Offline Sergio68Topic starter
« Reply #26 on: December 19, 2024, 12:15:15 pm »
No worries ! Don’t be sorry.
I’ll try to hook a scope.
Offline timeandfrequency
« Reply #27 on: December 19, 2024, 06:36:33 pm »
So I was curious if connecting a scope to those points XY mode could produce something (see the photos, it’s the analog entries of the crt command card )
So, four signals on small coax cables. It would be interesting to know if the shields of these coax are all at the same potential.
« Reply #28 on: December 20, 2024, 12:31:45 pm »
I’ll tell you what’s inside those wires.
Offline bsdphk
« Reply #29 on: December 20, 2024, 04:37:34 pm »
So I was curious if connecting a scope to those points XY mode could produce something […]
That picture is the HV drive card, that's not the right place.
Try looking at J4 and J5 on A1, I think those are the aux X+Y outputs at 0-1V DC, and J3 seems to be the Z to go with them.
The manual situation is somewhat messy for the 1345, because there are a number of different versions and options.
Some of the better copies of the doc is included in other instruments manuals, notably the 3577 which may have been the first time it was used.
On version had three 3-pin connectors where XYZ could be looped through external circuitry to multiplex analog signals, I think the 8981 may have used that model.
Ohh, and one more thing:  If your problem is "badly out of focus" you should check if there is an external focus pot attached, or if there should have been.  Check the jumper (it's in the manual)
« Reply #30 on: December 20, 2024, 06:47:44 pm »
It would be so nice to provide some links to all of these service and user manuals
« Reply #31 on: December 20, 2024, 11:24:59 pm »
Oh cool! Thanks a lot bsdphk!
I’ll share the links for operating and service manuals.
Of course and share more photos.
Thanks again!
« Reply #32 on: December 25, 2024, 08:29:12 am »
« Reply #33 on: December 25, 2024, 08:32:58 am »
And service manual :
http://www.petergottlieb.com/docs/hp/3582/hp3582a_svc.pdf
I wish you a happy and merry Christmas !
Thanks a lot for support.
I’ll probably start soon some tests.
