Author Topic: log opamp question  (Read 2832 times)
Offline electronics manTopic starter
log opamp question
« on: February 02, 2014, 05:19:27 pm »
I have been experimenting with log opamp circuits. the equation is Vout = K ln (Vin/Vref). I am confused as to what k is and Vref is can someone help? i am using the standerd opamp with a diode in the feed back loop of an opamp.
follow me on twitter @get_your_byte
Offline Rory
Re: log opamp question
« Reply #1 on: February 02, 2014, 05:22:51 pm »
« Reply #2 on: February 02, 2014, 05:24:58 pm »
I looked it doesnt explain much
« Reply #3 on: February 02, 2014, 05:59:49 pm »
All it does is say what it is not explain it
Offline Rudane
    • Electrical Engineering 101
« Reply #4 on: February 02, 2014, 06:39:27 pm »
electronics man: Follow the first link in external references and scroll down to the section around equations 5 and 6. Look at the two equations and deduce what K must be from them.
Voltage appears across and current flows through.
Offline Rory
« Reply #5 on: February 02, 2014, 07:11:38 pm »
Sorry I was terse, didn't have time to make a long-winded explanation. To further confuse you, and instead of spoon feeding you information I could possibly get wrong,  here is a credible source for you to study.
Analog Device's Log Amp Basics tutorial.
http://www.analog.com/static/imported-files/tutorials/MT-077.pdf
Go to page 4 for the diode log amp.
The point is, sharpen your Google-Fu. Research it for yourself from manufacturer's data sheets, appnotes and tutorials instead of asking on a forum where some pendantic know-it-all can give you the wrong answer.
