Hello again,
Thank you all for taking the time to answer my question, I realise now that I need to work on how I present my questions haha. This question is a pure hypothetical question meant to further enlarge my understanding of the earthing concept. I feel asif I'm having problems understanding the earthing concept.
I understand that one needs to reference metal enclosures of equipents to earth to prevent dangerous situations from happening, but batteries? Should one reference them to earth as well? I can see the point of earthing the metal enclosure of a circuit , but what hapens if I ALSO earth the battery in the same circuit?
In the case of mains powered equipment, the mains power supply is already referenced to earth, to prevent it from floating, at much higher voltages, relative to earth, due to something like a lightning strike. If a piece of equipment has a conductive case, it needs to be earthed, so the user doesn't receive a shock, if a fault develops, which causes the case to become connected to the mains. There are of course exceptions, such as when all the electrical circuits inside the case are enclosed in an insulating shield, which makes it impossible for the case to become live, if a wire breaks off.
In the case of a battery operated device, there is no requirement for the case to be connected to earth or the battery. Quite often the battery's negative terminal is connected to the case, because it improves screening and reduces interference.
What I meant to say in a more practical way was: Say I have a 12V DC circuit powered by a battery. If I reference the 0V of the battery to earth instead of keeping it flooting, what would happen? will current flow from plus to earth discharing the battery? Is it even wise to reference the 0V of a battery to earth? In this same circuit I have earthed the metal enclousure of the circuit.
Sorry for not being clear the last time, I do wish to understand this concenpt. If There is any selfstudy I can do to understand this concept, point me to it haha:)
The short answer to this question is no current will flow, without a return path to the battery. There needs to be a conductive path, between the anode and cathode of the battery, in order for a current to flow and simply connecting one battery terminal to earth, will not cause this to happen.
The long answer is, the total charge on the whole battery never actually changes, as it's "discharged". The entire battery contains the same number of electrons, irrespective of its state of charge. When the battery is discharged, electrons flow from the cathode, to the anode of the battery. When the battery is charged, an external voltage source is applied which moves the electrons back from the anode, to the cathode of the battery.
*SEE EDIT BELOWCharge is relative. If we add or remove electrons to the entire battery, then it will become electrostatically charged, with respect to the surrounding environment, but this would not affect the difference in charge between the anode and cathode of the battery. A 1Ah battery would power a circuit for the same length of time, if we removed or added electrons from the entire battery.
EDIT:
When the battery is charged, the same electron doesn't travel from the cathode, through the circuit and back tot the anode. The electric field pushes electrons out of the cathode, repelling other electrons in the conductor. Eventually an electron pushes out of the other end into the anode of the battery. The electrons themselves move very slowly, yet the time between the switched closing and the the current flowing through the circuit is extremely short.
A good analogy for this is, imagine a straight line of snooker balls, each touching one another. Gently tap the first one and the balls themselves will only move slowly, yet the time between the first ball and last ball moving will be almost instant.
