I'm working on a small project for which I need to generate a clock signal.
I'd typically use a 555 timer, but I need higher frequencies, approaching 10mhz. So that's not going to cut it.
I'm sure there are great options out there for this kind of circuit. However, I'm far from an expert in electronics, and I mostly need something that's easy to use ("programmed" externally, like a 555).
I'd really like to be able to adjust the output frequency, which is why I don't really want to use a simple crystal oscillator.
Jitter isn't too much of a concern, but I do need an LVCMOS output to work with the discrete 74 series chips I'll be using.
What options do I have here?
Again, I'm a noob here, so feel free to point out if I'm ignoring something obvious.
