Author Topic: 12 volt soldering irons  (Read 3800 times)
Offline dtRCasaTopic starter
« on: January 07, 2015, 10:26:53 pm »
It would be good to power a soldering iron from the car battery
while working on the car, but Weller wants an astonishing $125.90
for a 12 volt soldering iron, No. TCP12P. Seems excessive, why
can't i just connect the battery to a $5.00 iron?
Offline kingofkya
Re: 12 volt soldering irons
« Reply #1 on: January 07, 2015, 10:30:50 pm »
Ohms law....
The heater is just a big resistor.
Online Howardlong
« Reply #2 on: January 07, 2015, 10:42:48 pm »
I bought a 12V iron from Radio Shack several years ago, ISTR it was about $20 or so.
Alternatively, how about an inverter, or a gas iron?
Offline kingofkya
« Reply #3 on: January 07, 2015, 10:53:13 pm »
Offline sleemanj
  • Professional tightwad.
« Reply #4 on: January 07, 2015, 11:02:35 pm »
You can get on eBay unregulated DC irons, some are just typical 936 handles direct wired...
and there are proper drivers for various handles which can take a DC voltage down to 12v, add your own handle...
Offline theoldwizard1
« Reply #5 on: January 07, 2015, 11:20:04 pm »
I have one of those Weller irons and it is really very nice !  40W but the temperature is controlled by a standard Weller  Curie temperature tip.
Offline Wilksey
« Reply #6 on: January 08, 2015, 12:17:20 am »
I have a Weller gas powered one, and I must say, it works quite well for working on cars etc.
Offline dan.soethe
« Reply #7 on: January 08, 2015, 07:20:30 pm »
I have a butane powered one, I use it all the time when there's no power near by.
Offline W8LV
  • W8LV (and sometimes W8LV/VE3) USA/Canada
« Reply #8 on: January 09, 2015, 08:01:29 am »
Butane, but you have to really be careful around all of the carpet and vinyl so that you start one Hell of a car fire.
Best Regards from W8LV in Pickaway County, Ohio, USA
Offline W8LV
« Reply #9 on: January 09, 2015, 08:02:27 am »
....so that you DON'T start a car fire... ;
Offline amyk
« Reply #10 on: January 09, 2015, 01:42:30 pm »
12V on a 24V/50W iron will not produce 25W, it will be 12.5W...
Offline macboy
« Reply #11 on: January 09, 2015, 03:10:05 pm »
A standard soldering iron doesn't use much power, how about using a small inverter with a 120 V soldering iron?
Or try a butane soldering iron. I have one and I really like it. I pulled it out the other day when I needed to do a small job just a few feet away from the bench, instead of using a basic iron. The biggest issue with these is controlling the temperature manually.
