I could not hear it, at all. But, common sound issues with this type unit would be transformer hum and/or a loud fan. Some transformer hum might be considered normal. But, excessive noise can be due to...
- Loose transformer mounting bolts. Try just tightening them, snugly. Do not bare down and strip them out.
- No rubber pads, between the case and transformer frame. If not present, maybe add them. But, be sure to maintain the ground, somehow.
- Poor electrical connections, causing the transformer to labor. Try gently compressing any loose spade connections.
- A cheap transformer, lacking proper internal wire insulation/potting.
As for the fan, same as the transformer... Loose mounting bolts... No mounting rubber grommets... Cheap quality...
Remember, opening the case can void the warranty. Use proper safety techniques, if you do. Unplug the unit and drain the capacitors, for sure.
