Author Topic: Beginner Question on Comparator.  (Read 1040 times)
Offline n0bTopic starter
  • Let the experiment be made.
« on: November 10, 2015, 11:52:49 pm »
I found an IC in a power supply, the Texas Instruments Lm393, which I read is called a low power dual voltage comparator. What does a low power dual voltage comparator do?
http://www.st.com/web/catalog/sense_power/FM123/SC60/SS1089/LN1605/PF63723
Offline Len
Re: Beginner Question on Comparator.
« Reply #1 on: November 11, 2015, 12:12:10 am »
It compares two voltages and tells you which is higher.
https://en.wikipedia.org/wiki/Comparator
"Dual" means there are two separate comparators in the one chip.
DIY Eurorack Synth: https://lenp.net/synth/
