Author Topic: Voltage dropping for DC motors  (Read 1936 times)
Offline bcrossTopic starter
« on: January 31, 2015, 07:23:58 pm »
Hi guys,
I am a complete newbie to electronics having brought an Arduino a few months ago and what can I say I'm hooked! Anyway forgive me for my low level of knowledge.
I want to power two DC motors with a 5V source (powering a dual H-bridge IC controller connected to arduino) but according to the datasheet the DC motor is only rated 1.5-3.0V. The H-bridge must be supplied 4.5-36V. I was thinking I could drop the voltage across each motor by placing resistors in series. However (I can't get a decent resistance reading and) I am concerned that the resistors will overheat (burn out). Is it really a bad idea to supply 5v to a 3.0V max rated motor? If so what is the best (also cheap!) way of dropping the output voltage from the H-bridge?
Ben
Motor Datasheet: https://www.pololu.com/file/download/fa_130ra.pdf?file_id=0J11
H-bridge Datasheet: http://www.ti.com/lit/ds/symlink/l293d.pdf
Online Zero999
  • 0999
Re: Voltage dropping for DC motors
« Reply #1 on: January 31, 2015, 07:36:01 pm »
Don't worry about it. The datasheet says the h-bridge drops a couple of volts so with 5V in, the voltage across the motor will be not much more than 3V.
Online langwadt
« Reply #2 on: January 31, 2015, 07:36:27 pm »
Hi guys,
Ben
An L293 powered by 5V will give you less than 3V  on the motor
look at Voh and Vol on page 5 of data sheet
« Reply #3 on: January 31, 2015, 07:39:07 pm »
Brilliant! Thanks guys.
