Author Topic: voltage to current converter circuit analysis  (Read 2323 times)
Offline manjunathTopic starter
« on: December 03, 2014, 09:46:25 am »
Hi all,
I am new to electronics  circuits and i know basics about the Op-Amp. I need to know how the voltage across inverting terminal changes wrt voltage change across non inverting terminal.
Please help me to analysis the attached circuit.
Thanks.
Online tggzzz
Re: voltage to current converter circuit analysis
« Reply #1 on: December 03, 2014, 10:07:15 am »
General starting principle with any opamp circuit that is operating "normally": the output does whatever is necessary to ensure that the inverting and non-inverting inputs are at the same voltage. If they aren't then the output voltage will be the (very high) open-loop gain times the voltage difference.
There are many many introductions to opamps on the web; google is your friend.
« Reply #2 on: December 03, 2014, 11:30:45 am »
ya i have gone though some basics about op amp. Here my doubt is for a voltage above 1.7V across non inverting terminal i can able to get both inverting terminal and non inverting voltage at same value (I think at this time gives high output voltage) and for a voltage level below 1.7V across non inverting terminal i am getting a voltage of 2.5V across the inverting terminal.  Why i am getting this difference ?
Offline Seekonk
« Reply #3 on: December 03, 2014, 02:41:04 pm »
R3 is going to have the drive current & the transistor current.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #4 on: December 03, 2014, 08:01:21 pm »
What is the arrow at the base of R3?  That doesn't look like a Multisim standard.
Seven Transistor Labs, LLC
Online IanB
« Reply #5 on: December 03, 2014, 08:14:14 pm »
It looks like the numeral 4 overlaid on top of the line?
