Author Topic: TI BQ78350 confusing schematic  (Read 1091 times)
Offline redgearTopic starter
« on: July 24, 2019, 07:05:41 am »
I am trying to reproduce the sample schematic from the for TI BQ78350, however the pin out of the IC is different in the schematic and pin diagram. I'm a bit confused.
This is how it is in the schematic
This is how the pins are numbered
Thanks
Edit: The IC on the right in the first image is the BQ78350
« Last Edit: July 24, 2019, 07:13:01 am by redgear »
Offline bitwelder
Re: TI BQ78350 confusing schematic
« Reply #1 on: July 24, 2019, 07:19:52 am »
In the simplified schematic the pins seem to be sorted in functional order (i.e. conveniently to draw a readable schematic), not strictly according to the pinout.
« Reply #2 on: July 24, 2019, 08:03:26 am »
Thanks, so if I am building this component on an EDA, I should follow the Pin Diagram (second image), correct?
Offline bitwelder
« Reply #3 on: July 24, 2019, 09:13:03 pm »
Yep!
The following users thanked this post: redgear
